Introduction
The instructions in this guide will cover the process to remove the Optical Drive for a Dell Inspiron M5110. This is necessary to replace the drive, which should be done when the computer can no longer read DVD or CD discs.
Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
Remove the module cover pressing in the release tabs and pulling the cover up and away from the base of the device.
Insert a small screwdriver into the hole and slide the bracket away from the center of the device. This will slide the optical assembly out from the side of the device enough to grasp.
