Dell Inspiron E1505 Battery Replacement
  1. Dell Inspiron E1505 Battery Replacement, Battery: step 1, image 1 of 1
    • Before any work can be done ensure that the laptop is powered off.
    • Use either the power button on the computer or issue a shutdown from the operating system.
    • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
  2. Dell Inspiron E1505 Battery Replacement: step 2, image 1 of 1
    • Locate the battery release switch on the bottom of the laptop.
    • Once located slide the switch into the unlock position.
  3. Dell Inspiron E1505 Battery Replacement: step 3, image 1 of 1
    • Locate the “lip” on the laptop to lift the battery outside of the compartment.
    • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
  4. Dell Inspiron E1505 Battery Replacement: step 4, image 1 of 1
    • Once the new battery has been acquired take the battery and place it in the empty battery slot.
    • Slide the switch into the lock position to secure the new battery.
Anthony Toscano
323 Reputation
3 Guides authored
UMass Dartmouth, Team 6-7, Martin Fall 2016 Member of UMass Dartmouth, Team 6-7, Martin Fall 2016
UMASSD-MARTIN-F16S6G7
3 Members
4 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 13
All Time: 580
