You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
The disk drive lets you install drivers from disks and many other useful things. This is a simple replacement and should only be done if there is no way the disk drive could ever operate correctly.
Parts
No parts specified.
  1. First, make sure your computer is turned off.
    • First, make sure your computer is turned off.
    • Flip your computer over and you can see the battery.
  2. Push the tab from the battery, downwards to unlock the battery. The tab should be in the position next to the unlocked indicator. The tab should be in the position next to the unlocked indicator.
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Now, push the other tab (the one right under the battery) from right to left. Now the battery will be loose; lift the battery up and out of the computer. Now the battery will be loose; lift the battery up and out of the computer.
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Remove the 8mm screw Use the plastic opening tool to push out the disk drive. Pull the disk drive out with the opposite hand.
    • Remove the 8mm screw
    • Use the plastic opening tool to push out the disk drive.
    • Pull the disk drive out with the opposite hand.
  5. You can now remove the disk drive.
    • You can now remove the disk drive.
Patrick McNeil
913 Reputation
8 Guides authored
UMass Dartmouth, Team 1-8, Catania Fall 2016 Member of UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
3 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 69
