Dell Inspiron B130 CPU Replacement
  1. Dell Inspiron B130 CPU Replacement, Battery: step 1, image 1 of 3 Dell Inspiron B130 CPU Replacement, Battery: step 1, image 2 of 3 Dell Inspiron B130 CPU Replacement, Battery: step 1, image 3 of 3
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 CPU Replacement: step 2, image 1 of 3 Dell Inspiron B130 CPU Replacement: step 2, image 2 of 3 Dell Inspiron B130 CPU Replacement: step 2, image 3 of 3
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 CPU Replacement: step 3, image 1 of 3 Dell Inspiron B130 CPU Replacement: step 3, image 2 of 3 Dell Inspiron B130 CPU Replacement: step 3, image 3 of 3
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 CPU Replacement, CPU: step 4, image 1 of 2 Dell Inspiron B130 CPU Replacement, CPU: step 4, image 2 of 2
    • Remove the 6 mm screw
    • Lift the plastic cover off.
  5. Dell Inspiron B130 CPU Replacement: step 5, image 1 of 2 Dell Inspiron B130 CPU Replacement: step 5, image 2 of 2
    • Loosen the 4 screws.
    • These screws stay connected to the heat sink.
    • Remove the heat sink from the computer.
  6. Dell Inspiron B130 CPU Replacement: step 6, image 1 of 1
    • Use a flat head screwdriver to turn the screw one quarter turn into the unlock position.
    • Remove the CPU.
Patrick McNeil
937 Reputation
8 Guides authored
UMass Dartmouth, Team 1-8, Catania Fall 2016 Member of UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
3 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 361
