Dell Inspiron 9100 Memory Replacement
  1. Dell Inspiron 9100 Memory Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 9100 Memory Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 9100 Memory Replacement, Battery: step 1, image 3 of 3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Memory Replacement: step 2, image 1 of 3 Dell Inspiron 9100 Memory Replacement: step 2, image 2 of 3 Dell Inspiron 9100 Memory Replacement: step 2, image 3 of 3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Memory Replacement, Memory: step 3, image 1 of 2 Dell Inspiron 9100 Memory Replacement, Memory: step 3, image 2 of 2
    • Using the Philips #00 screwdriver, undo the screw on the memory module cover, labeled "M."
    • This screw will remain in the panel.
    • Pull the cover away from the laptop using your finger.
  4. Dell Inspiron 9100 Memory Replacement: step 4, image 1 of 3 Dell Inspiron 9100 Memory Replacement: step 4, image 2 of 3 Dell Inspiron 9100 Memory Replacement: step 4, image 3 of 3
    • Use your fingertips to carefully spread apart the plastic white tabs.
    • Flip the RAM up at a 45 degree angle and remove it.
    • Hold the RAM by the edges only.
    • Ground yourself while dealing with RAM. Static shock can damage the memory. Store the RAM in an anti-static bag while it is not in use.
  5. Dell Inspiron 9100 Memory Replacement: step 5, image 1 of 1
    • Repeat step four with the second RAM.
charlierefvem
854 Reputation
7 Guides authored
Cal Poly, Team 13-2, Forte Winter 2011 Member of Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 18
All Time: 3,505
