Dell Inspiron 910 Solid-State Drive (SSD) Replacement
  1. Dell Inspiron 910 Solid-State Drive (SSD) Replacement, Remove screws from SSD: step 1, image 1 of 1
    • "CAUTION"If you remove the solid-state drive from the computer when the drive is hot, do not touch the solid-state drive
    • Remove the two screws that secure the solid-state drive.
    • Lift the solid-state drive out of its system board connector.
    • Insert the solid-state drive into the slot at a 45-degree angle.
    • Press the solid-state drive down and replace the two screws that secure the drive.
    • Replace the module cover
    • Slide the battery into the battery bay, until it clicks into place and slide the battery-lock latch towards the lock position.
    • Make sure to replace all screws and ensure that there are no stray bolts.
Devyn Johnson
232 Reputation
2 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 14
All Time: 606
