Dell Inspiron 8600 Hinge Cover Replacement
  1. Dell Inspiron 8600 Hinge Cover Replacement, Battery: step 1, image 1 of 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Hinge Cover Replacement, Hinge Cover: step 2, image 1 of 3 Dell Inspiron 8600 Hinge Cover Replacement, Hinge Cover: step 2, image 2 of 3 Dell Inspiron 8600 Hinge Cover Replacement, Hinge Cover: step 2, image 3 of 3
    • Insert a spludger into the notch at the far left side of the top blue panel and pry hinge cover off.
    • Note: You may need to pry the other side off by inserting the spludger between the hinge and the top cover.
    • Be careful of wire attached to underside of the hinge cover.
  3. Dell Inspiron 8600 Hinge Cover Replacement: step 3, image 1 of 1
    • Pull the small black tab on the right hand side of the laptop.
    • The hinge cover has now been removed.
John Nesthus
186 Reputation
6 Guides authored
Cal Poly, Team 18-22, Garner Spring 2011 Member of Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Members
16 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 3,485
