Dell Inspiron 8600 Display Removal
  1. Dell Inspiron 8600 Display Removal, Battery: step 1, image 1 of 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Display Removal, Hinge Cover: step 2, image 1 of 3 Dell Inspiron 8600 Display Removal, Hinge Cover: step 2, image 2 of 3 Dell Inspiron 8600 Display Removal, Hinge Cover: step 2, image 3 of 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Display Removal: step 3, image 1 of 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Display Removal, Display Module: step 4, image 1 of 2 Dell Inspiron 8600 Display Removal, Display Module: step 4, image 2 of 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  5. Dell Inspiron 8600 Display Removal: step 5, image 1 of 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  6. Dell Inspiron 8600 Display Removal: step 6, image 1 of 2 Dell Inspiron 8600 Display Removal: step 6, image 2 of 2
    • Lift the display module directly upwards.
  7. Dell Inspiron 8600 Display Removal: step 7, image 1 of 1
    • The display module has been removed.
Victor
187 Reputation
1 Guide authored
Cal Poly, Team 18-22, Garner Spring 2011 Member of Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Members
16 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 3,868
