Dell Inspiron 6000 Fan Replacement
  1. Dell Inspiron 6000 Fan Replacement, Battery: step 1, image 1 of 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 Fan Replacement: step 2, image 1 of 1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 Fan Replacement, Keyboard: step 3, image 1 of 3 Dell Inspiron 6000 Fan Replacement, Keyboard: step 3, image 2 of 3 Dell Inspiron 6000 Fan Replacement, Keyboard: step 3, image 3 of 3
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
  4. Dell Inspiron 6000 Fan Replacement: step 4, image 1 of 2 Dell Inspiron 6000 Fan Replacement: step 4, image 2 of 2
    • Remove two 4 mm Philips #00 screws.
  5. Dell Inspiron 6000 Fan Replacement: step 5, image 1 of 1
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
  6. Dell Inspiron 6000 Fan Replacement: step 6, image 1 of 3 Dell Inspiron 6000 Fan Replacement: step 6, image 2 of 3 Dell Inspiron 6000 Fan Replacement: step 6, image 3 of 3
    • Gently pull the blue tab up until it comes away from computer.
  7. Dell Inspiron 6000 Fan Replacement, Fan: step 7, image 1 of 1
    • Unscrew the 4 mm Phillips #00 screw.
    • The screw will remain attached to the cord when fully removed.
  8. Dell Inspiron 6000 Fan Replacement: step 8, image 1 of 2 Dell Inspiron 6000 Fan Replacement: step 8, image 2 of 2
    • Gently pull the blue tab to separate the screen connection from the laptop.
    • Gently pull and disconnect the white and black cords from the power source.
  9. Dell Inspiron 6000 Fan Replacement: step 9, image 1 of 2 Dell Inspiron 6000 Fan Replacement: step 9, image 2 of 2
    • Remove four 4mm #00 Philips screws from the screen hinges.
    • Lift the screen away from the laptop.
  10. Dell Inspiron 6000 Fan Replacement: step 10, image 1 of 2 Dell Inspiron 6000 Fan Replacement: step 10, image 2 of 2
    • Remove two 4 mm Philips #00 screws that connect top of laptop to base..
  11. Dell Inspiron 6000 Fan Replacement: step 11, image 1 of 1
    • Flip laptop the over and remove thirteen 4mm Philips #00 screws.
  12. Dell Inspiron 6000 Fan Replacement: step 12, image 1 of 2 Dell Inspiron 6000 Fan Replacement: step 12, image 2 of 2
    • Insert the plastic opening tool in between the back and front plates of the laptop
  13. Dell Inspiron 6000 Fan Replacement: step 13, image 1 of 1
  14. Dell Inspiron 6000 Fan Replacement: step 14, image 1 of 1
    • Remove the fan power cord
  15. Dell Inspiron 6000 Fan Replacement: step 15, image 1 of 2 Dell Inspiron 6000 Fan Replacement: step 15, image 2 of 2
    • Using your hand, lift the fan from the laptop.
Jacob DeWar
533 Reputation
3 Guides authored
USF Tampa, Team 11-1, Blackwell Fall 2014 Member of USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 2,198
