Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement
  1. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement, PCI Slot: Dial up modem: step 1, image 1 of 2 Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement, PCI Slot: Dial up modem: step 1, image 2 of 2
    • Unscrew the two large screws in the back holding on the side panel.
    • Slide the panel backwards to remove it.
  2. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: step 2, image 1 of 3 Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: step 2, image 2 of 3 Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: step 2, image 3 of 3
    • The PCI slots are located at the bottom back of the computer.
    • Unscrew the screw to release the metal piece that holds the cards in place.
    • Remove metal piece.
  3. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: step 3, image 1 of 2 Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: step 3, image 2 of 2
    • Slide the card in the PCI slot up and out.
    • In this case, it is a dial up modem.
  4. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: step 4, image 1 of 3 Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: step 4, image 2 of 3 Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: step 4, image 3 of 3
    • Take the new card and slide it into the slot that you removed the old one out of.
    • Remember to replace the metal piece you removed earlier to secure the cards in place.
Drew Cunningham
656 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 830
