Dell Inspiron 1750 Screen Replacement
  1. Dell Inspiron 1750 Screen Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 1750 Screen Replacement, Battery: step 1, image 2 of 2
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Dell Inspiron 1750 Screen Replacement: step 2, image 1 of 2 Dell Inspiron 1750 Screen Replacement: step 2, image 2 of 2
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  3. Dell Inspiron 1750 Screen Replacement, Dell Inspiron 1750 Teardown: step 3, image 1 of 1
    • Separate the screws by size and head type. Be sure to keep them in a safe place.
    • Remove the sixteen 2mm Phillips #00 screws from the bottom of the laptop.
    • Remove the two 2mm Phillips #0 screws from the hard drive port.
  4. Dell Inspiron 1750 Screen Replacement: step 4, image 1 of 3 Dell Inspiron 1750 Screen Replacement: step 4, image 2 of 3 Dell Inspiron 1750 Screen Replacement: step 4, image 3 of 3
    • Keep your hand pressed firmly on the back panel to prevent it from falling.
    • Flip the laptop over horizontally and open up the lid.
    • Insert the tip of the plastic opening tool into the upper left corner of the panel.
    • Keeping its tip under the top panel, slide the plastic opening tool around the panel until the panel is completely loose. Next gently remove the panel.
    • Remove the four 2mm Phillips #0 screws at the top of the keyboard.
    • Slide the plastic opening tool around the keyboard until the keyboard is completely loose. Gently remove the keyboard.
  5. Dell Inspiron 1750 Screen Replacement: step 5, image 1 of 3 Dell Inspiron 1750 Screen Replacement: step 5, image 2 of 3 Dell Inspiron 1750 Screen Replacement: step 5, image 3 of 3
    • Do not lift the keyboard completely free to avoid damaging its connections to the laptop interior.
    • Locate the small black latch attached to blue tape.
    • Lift the small latch with your finger and pull the blue tape from its port.
    • Slide the keyboard away from the mousepad and set it aside.
  6. Dell Inspiron 1750 Screen Replacement: step 6, image 1 of 3 Dell Inspiron 1750 Screen Replacement: step 6, image 2 of 3 Dell Inspiron 1750 Screen Replacement: step 6, image 3 of 3
    • Always pull wires from their plastic ends, not their cables, to avoid wire damage.
    • Locate the three wires in the top left corner of the metal panel.
    • Use the spudger to push the two cables out of their ports.
    • Pull the blue tab directly up to remove middle wire.
  7. Dell Inspiron 1750 Screen Replacement: step 7, image 1 of 2 Dell Inspiron 1750 Screen Replacement: step 7, image 2 of 2
    • Remove the three 1mm Phillips #00 screws on the metal plate.
    • Lift the black cover and slide the blue tab away from the cover.
  8. Dell Inspiron 1750 Screen Replacement: step 8, image 1 of 3 Dell Inspiron 1750 Screen Replacement: step 8, image 2 of 3 Dell Inspiron 1750 Screen Replacement: step 8, image 3 of 3
    • Gently remove the three grey wires from the metal tabs.
    • Insert the tip of the plastic opening tool into the bottom left corner of the panel.
    • Gently lift off the top metal panel.
  9. Dell Inspiron 1750 Screen Replacement, Screen: step 9, image 1 of 3 Dell Inspiron 1750 Screen Replacement, Screen: step 9, image 2 of 3 Dell Inspiron 1750 Screen Replacement, Screen: step 9, image 3 of 3
    • Use the spudger to lift the wires from their connections.
    • Remember to pull wires from their plastic ends, not their cables, to avoid wire damage.
    • Flip the laptop over and pull the connections through until they are free from the laptop interior.
  10. Dell Inspiron 1750 Screen Replacement: step 10, image 1 of 2 Dell Inspiron 1750 Screen Replacement: step 10, image 2 of 2
    • Remove the two 2mm Phillips #0 screws from the screen hinges.
    • Lift the screen away from the laptop and gently set it down.
    • Put the rest of the laptop aside.
  11. Dell Inspiron 1750 Screen Replacement: step 11, image 1 of 3 Dell Inspiron 1750 Screen Replacement: step 11, image 2 of 3 Dell Inspiron 1750 Screen Replacement: step 11, image 3 of 3
    • Use the plastic opening tool to remove the plastic cover from the screen.
    • Remove the eight 2mm Phillips #0 screws from the corners of the screen.
    • Lift the screen away from the back panel.
  12. Dell Inspiron 1750 Screen Replacement: step 12, image 1 of 2 Dell Inspiron 1750 Screen Replacement: step 12, image 2 of 2
    • Remove the four 2mm Phillips #0 screws from the sides of the screen.
    • Remove the side railings from both sides of the screen by pulling the railings gently away from the screen.
Tina Rickard
759 Reputation
5 Guides authored
Cal Poly, Team 6-3, Forte Spring 2014 Member of Cal Poly, Team 6-3, Forte Spring 2014
CPSU-FORTE-S14S6G3
5 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 3,720
