Dell Inspiron 17-3721 Optical Drive Replacement
  1. Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: step 1, image 1 of 2 Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: step 1, image 2 of 2
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Optical Drive Replacement: step 2, image 1 of 2 Dell Inspiron 17-3721 Optical Drive Replacement: step 2, image 2 of 2
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
  3. Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: step 3, image 1 of 3 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: step 3, image 2 of 3 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: step 3, image 3 of 3
    • Remove the four 6 mm PH1 Philips head screws under the keyboard.
    • Carefully pop off the cover using the plastic opening tools and your hands.
  4. Dell Inspiron 17-3721 Optical Drive Replacement: step 4, image 1 of 3 Dell Inspiron 17-3721 Optical Drive Replacement: step 4, image 2 of 3 Dell Inspiron 17-3721 Optical Drive Replacement: step 4, image 3 of 3
    • Remove the 4 mm PH1 Philips head screw holding down the optical drive.
    • Use your hand to slide the drive out of the device.
Kevin Prairie
445 Reputation
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 311
