Dell Inspiron 1525 Wireless Mini-Card Replacement
  1. Dell Inspiron 1525 Wireless Mini-Card Replacement, Battery: step 1, image 1 of 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Wireless Mini-Card Replacement: step 2, image 1 of 2 Dell Inspiron 1525 Wireless Mini-Card Replacement: step 2, image 2 of 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Wireless Mini-Card Replacement, Bottom Cover: step 3, image 1 of 2 Dell Inspiron 1525 Wireless Mini-Card Replacement, Bottom Cover: step 3, image 2 of 2
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 Wireless Mini-Card Replacement, Wireless Mini-Card: step 4, image 1 of 2 Dell Inspiron 1525 Wireless Mini-Card Replacement, Wireless Mini-Card: step 4, image 2 of 2
    • Use the flat end of a spudger to gently pry the black and white antenna connectors off the Wireless Mini-Card.
  5. Dell Inspiron 1525 Wireless Mini-Card Replacement: step 5, image 1 of 2 Dell Inspiron 1525 Wireless Mini-Card Replacement: step 5, image 2 of 2
    • Remove the 3.70 mm Phillips #1 screw securing the card to the laptop.
    • The card will tilt up when you remove the screw.
    • Slide the card straight out.
Phillip Takahashi
86,747 Reputation
87 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 8,879
