Installing Dell Inspiron 1525 DC Power Board
  1. Installing Dell Inspiron 1525 DC Power Board, Battery: step 1, image 1 of 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Installing Dell Inspiron 1525 DC Power Board: step 2, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board: step 2, image 2 of 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Installing Dell Inspiron 1525 DC Power Board, Hard Drive: step 3, image 1 of 3 Installing Dell Inspiron 1525 DC Power Board, Hard Drive: step 3, image 2 of 3 Installing Dell Inspiron 1525 DC Power Board, Hard Drive: step 3, image 3 of 3
    • Remove the two 3.60 mm #1 Phillips screws securing the hard drive and hard drive tray.
    • Slide the hard drive and hard drive tray out of the laptop.
  4. Installing Dell Inspiron 1525 DC Power Board, Optical Drive: step 4, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board, Optical Drive: step 4, image 2 of 2
    • Remove the 5.75 mm #1 Phillips screw securing the optical drive.
    • Pull the optical drive straight from the laptop.
  5. Installing Dell Inspiron 1525 DC Power Board, Wireless Mini-Card: step 5, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board, Wireless Mini-Card: step 5, image 2 of 2
    • Use the flat end of a spudger to gently pry the black and white antenna connectors off the Wireless Mini-Card.
  6. Installing Dell Inspiron 1525 DC Power Board: step 6, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board: step 6, image 2 of 2
    • Remove the 3.70 mm Phillips #1 screw securing the card to the laptop.
    • The card will tilt up when you remove the screw.
    • Slide the card straight out.
  7. Installing Dell Inspiron 1525 DC Power Board, Central Control Cover: step 7, image 1 of 1
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  8. Installing Dell Inspiron 1525 DC Power Board: step 8, image 1 of 3 Installing Dell Inspiron 1525 DC Power Board: step 8, image 2 of 3 Installing Dell Inspiron 1525 DC Power Board: step 8, image 3 of 3
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  9. Installing Dell Inspiron 1525 DC Power Board: step 9, image 1 of 3 Installing Dell Inspiron 1525 DC Power Board: step 9, image 2 of 3 Installing Dell Inspiron 1525 DC Power Board: step 9, image 3 of 3
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
  10. Installing Dell Inspiron 1525 DC Power Board, Keyboard: step 10, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board, Keyboard: step 10, image 2 of 2
    • Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
    • Gently slide the keyboard towards the display until the tabs on its front side are free.
    • Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
  11. Installing Dell Inspiron 1525 DC Power Board: step 11, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board: step 11, image 2 of 2
    • Use a spudger to gently lift the ribbon cable retaining flap.
    • Disconnect the ribbon cable.
    • Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
  12. Installing Dell Inspiron 1525 DC Power Board, Display Assembly: step 12, image 1 of 3 Installing Dell Inspiron 1525 DC Power Board, Display Assembly: step 12, image 2 of 3 Installing Dell Inspiron 1525 DC Power Board, Display Assembly: step 12, image 3 of 3
    • Disconnect the five antennas from their respective cards.
    • De-route the antennas from their routing retainers.
  13. Installing Dell Inspiron 1525 DC Power Board: step 13, image 1 of 1
    • Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
    • The screw holes will be denoted by an embossed "D" by the hole.
  14. Installing Dell Inspiron 1525 DC Power Board: step 14, image 1 of 3 Installing Dell Inspiron 1525 DC Power Board: step 14, image 2 of 3 Installing Dell Inspiron 1525 DC Power Board: step 14, image 3 of 3
    • Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector.
    • Carefully release the connector from its retaining tabs.
  15. Installing Dell Inspiron 1525 DC Power Board: step 15, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board: step 15, image 2 of 2
    • Push the antenna wires up through their hole in the bottom case half.
    • Release the antennas from their retaining tabs on the upper case.
  16. Installing Dell Inspiron 1525 DC Power Board: step 16, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board: step 16, image 2 of 2
    • Disconnect the flat LCD ribbon cable by pulling it up by the tab.
    • Free the ribbon cable from its retaining clips.
  17. Installing Dell Inspiron 1525 DC Power Board: step 17, image 1 of 1
    • Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
    • Support the display assembly as you remove these screws to prevent damage to the screw and hole threads.
    • Remove the display assembly from the laptop.
  18. Installing Dell Inspiron 1525 DC Power Board, Upper Case: step 18, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board, Upper Case: step 18, image 2 of 2
    • Remove the nine 5.75 mm Phillips #1 screws on the bottom side of the laptop.
    • Remove the two 5.70 mm Phillips #1 screws on the top side of the laptop.
  19. Installing Dell Inspiron 1525 DC Power Board: step 19, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board: step 19, image 2 of 2
    • Use a spudger to pull the touch pad connector latch towards the ribbon cable.
    • Pull the ribbon cable out of the connector.
  20. Installing Dell Inspiron 1525 DC Power Board: step 20, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board: step 20, image 2 of 2
    • Use a spudger to pull the device status LED connector latch towards the ribbon cable.
    • Disconnect the device status LED ribbon cable.
  21. Installing Dell Inspiron 1525 DC Power Board: step 21, image 1 of 3 Installing Dell Inspiron 1525 DC Power Board: step 21, image 2 of 3 Installing Dell Inspiron 1525 DC Power Board: step 21, image 3 of 3
    • Release the ribbon cable in the upper left corner of the laptop from its retaining tabs.
    • Use a spudger to unplug the speaker connector at the top center of the laptop.
    • De-route the speaker wires from their retaining tabs.
  22. Installing Dell Inspiron 1525 DC Power Board: step 22, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board: step 22, image 2 of 2
    • Use the flat end of a spudger to begin lifting the upper case at its front edge.
    • Lift the front edge of the case up until it comes free.
    • Work slowly and be sure not to get any cables caught in the upper case holes and guides.
  23. Installing Dell Inspiron 1525 DC Power Board, ExpressCard Cage: step 23, image 1 of 3 Installing Dell Inspiron 1525 DC Power Board, ExpressCard Cage: step 23, image 2 of 3 Installing Dell Inspiron 1525 DC Power Board, ExpressCard Cage: step 23, image 3 of 3
    • Eject your ExpressCard or ExpressCard dust shield if you want to transfer it to the new ExpressCard cage. Eject the card by pressing it in until it clicks, releasing it, then sliding it out.
    • Remove the 3.80 mm Phillips #1 screw securing the ExpressCard cage.
    • Remove the two 3.70 mm Phillips #1 screws securing the ExpressCard cage.
    • Lift the ExpressCard cage out of its connector.
  24. Installing Dell Inspiron 1525 DC Power Board, Heat Sink: step 24, image 1 of 3 Installing Dell Inspiron 1525 DC Power Board, Heat Sink: step 24, image 2 of 3 Installing Dell Inspiron 1525 DC Power Board, Heat Sink: step 24, image 3 of 3
    • Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air
    • These screws are attached to the heat sink assembly.
    • Gently lift the heat sink from side indicated in the picture.
    • The heat sink may feel like it is glued to the chips because of the thermal paste. Gently wiggle the heat sink back and forth to help break it free.
    • Be sure to thoroughly clean off the old thermal paste and apply new thermal paste before reinstalling the heat sink. Follow our thermal paste application guide for detailed instructions.
  25. Installing Dell Inspiron 1525 DC Power Board, Motherboard: step 25, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board, Motherboard: step 25, image 2 of 2
    • Use a spudger to push the retaining latch of the central control button connector towards its cable.
    • Pull the cable out of the connector.
  26. Installing Dell Inspiron 1525 DC Power Board: step 26, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board: step 26, image 2 of 2
    • Pull the retaining latch for the wireless sniffer cable out.
    • Remove the cable from the connector.
  27. Installing Dell Inspiron 1525 DC Power Board: step 27, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board: step 27, image 2 of 2
    • Disconnect the fan cable connector by pulling it towards the fan with a spudger.
  28. Installing Dell Inspiron 1525 DC Power Board: step 28, image 1 of 3 Installing Dell Inspiron 1525 DC Power Board: step 28, image 2 of 3 Installing Dell Inspiron 1525 DC Power Board: step 28, image 3 of 3
    • Remove the four 3.70 mm Phillips #1 screws securing the motherboard to the lower case.
    • Gently peel the front bezel off.
    • Lift the motherboard out of the lower case.
    • If you are installing a new motherboard, make sure to transfer any remaining cables onto the new motherboard, as well as the CPU, RAM, modem, and Wi-Fi card.
  29. Installing Dell Inspiron 1525 DC Power Board, DC Power Board: step 29, image 1 of 2 Installing Dell Inspiron 1525 DC Power Board, DC Power Board: step 29, image 2 of 2
    • Unscrew the single screw holding the DC charger board into the laptop and lift it out.
Country Computer Service
11,602 Reputation
1 Guide authored
Master Techs Member of Master Techs
Community
321 Members
1,494 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 13,874
