Dell Inspiron 1525 Central Control Cover Replacement
  1. Dell Inspiron 1525 Central Control Cover Replacement, Battery: step 1, image 1 of 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Central Control Cover Replacement: step 2, image 1 of 2 Dell Inspiron 1525 Central Control Cover Replacement: step 2, image 2 of 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Central Control Cover Replacement, Central Control Cover: step 3, image 1 of 1
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 Central Control Cover Replacement: step 4, image 1 of 3 Dell Inspiron 1525 Central Control Cover Replacement: step 4, image 2 of 3 Dell Inspiron 1525 Central Control Cover Replacement: step 4, image 3 of 3
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 Central Control Cover Replacement: step 5, image 1 of 3 Dell Inspiron 1525 Central Control Cover Replacement: step 5, image 2 of 3 Dell Inspiron 1525 Central Control Cover Replacement: step 5, image 3 of 3
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 3,593
