Dell Inspiron 15-3521 RAM Replacement
  1. Dell Inspiron 15-3521 RAM Replacement, Remove the battery: step 1, image 1 of 3 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: step 1, image 2 of 3 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: step 1, image 3 of 3
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 RAM Replacement, Remove access door: step 2, image 1 of 3 Dell Inspiron 15-3521 RAM Replacement, Remove access door: step 2, image 2 of 3 Dell Inspiron 15-3521 RAM Replacement, Remove access door: step 2, image 3 of 3
    • Loosen the two screws attaching the access door to the laptop body
    • Using a spudger, pry open the access door from the laptop
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: step 3, image 1 of 3 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: step 3, image 2 of 3 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: step 3, image 3 of 3
    • To access the memory cards, push out the latches on the left and right of the memory cards
    • To remove the memory card, pull it out of the tray with the latches still stretched out
    • Insert a new memory card in to the memory card tray, depressing until side latches engage with a click.
Andrew Dippre
2,902 Reputation
7 Guides authored
Clemson, Team 3-1, Benson Fall 2014 Member of Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 30
All Time: 6,253
