Dell Inspiron 14z-5423 Keyboard Replacement
  1. Dell Inspiron 14z-5423 Keyboard Replacement, RAM: step 1, image 1 of 2 Dell Inspiron 14z-5423 Keyboard Replacement, RAM: step 1, image 2 of 2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Keyboard Replacement: step 2, image 1 of 1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Keyboard Replacement: step 3, image 1 of 2 Dell Inspiron 14z-5423 Keyboard Replacement: step 3, image 2 of 2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Keyboard Replacement: step 4, image 1 of 2 Dell Inspiron 14z-5423 Keyboard Replacement: step 4, image 2 of 2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Keyboard Replacement: step 5, image 1 of 2 Dell Inspiron 14z-5423 Keyboard Replacement: step 5, image 2 of 2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: step 6, image 1 of 3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: step 6, image 2 of 3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: step 6, image 3 of 3
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  7. Dell Inspiron 14z-5423 Keyboard Replacement: step 7, image 1 of 1
    • Flip over the computer and open the display.
  8. Dell Inspiron 14z-5423 Keyboard Replacement: step 8, image 1 of 2 Dell Inspiron 14z-5423 Keyboard Replacement: step 8, image 2 of 2
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  9. Dell Inspiron 14z-5423 Keyboard Replacement: step 9, image 1 of 2 Dell Inspiron 14z-5423 Keyboard Replacement: step 9, image 2 of 2
    • Flip the keyboard over onto the palm-rest assembly.
  10. Dell Inspiron 14z-5423 Keyboard Replacement: step 10, image 1 of 3 Dell Inspiron 14z-5423 Keyboard Replacement: step 10, image 2 of 3 Dell Inspiron 14z-5423 Keyboard Replacement: step 10, image 3 of 3
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
Marisol
623 Reputation
4 Guides authored
CSU Fullerton, Team 2-2, Bruce Fall 2016 Member of CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
5 Members
11 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 1,473
