Dell Inspiron 14-5425
  1. Dell Inspiron 14-5425, Screw removing (and addons): step 1, image 1 of 1
    • Flip your laptop rearside up. Make sure not to scratch anything while doing so.
    • Remove anything attached to your laptop and start unscrewing.
    • The blue circled screws are "stand-off screws", they shouldn’t come out the rear shell. Keep unscrewing until each of them start to make a "clicking" noise.
    • The red circled screws are normal, they are all the same size and should come out.
  2. Dell Inspiron 14-5425, Lid removal: step 2, image 1 of 1
    • All the screws should be off except the "stand-off" screws.
    • Slide a pick or card around the computer lid. Don't dig too deep or you might hit something
    • Be wary that there is a clip near the middle of the rear shell. Lift the shell off with equal pressure. Make sure to take your time to prevent anything going wrong.
  3. Dell Inspiron 14-5425, Cable disconnection/removal: step 3, image 1 of 3 Dell Inspiron 14-5425, Cable disconnection/removal: step 3, image 2 of 3 Dell Inspiron 14-5425, Cable disconnection/removal: step 3, image 3 of 3
    • The lid should come back off
    • Find the battery cable (near the bottom right)
    • Lift off a bit of the cable cover and use a tool to disconnect the cable
    • Disconnect the cable by pushing the cable out
  4. Dell Inspiron 14-5425, Battery removal: step 4, image 1 of 1
    • Unscrew the battery from the laptop. All the screws are the same size
    • Use a card or pick to detach the battery
    • The battery isn’t glued in, it should be free
  5. Dell Inspiron 14-5425, Done: step 5, image 1 of 1
    • You are done!
WakandaMan99
122 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 20
All Time: 362
