Introduction
This guide to remove your Dell Inspiron 13-7359 screen. You will need a phillips #0 screwdriver and a small plastic spudger. This guide will require more time and is more difficult than the other replacement guides.
First flip over the laptop to expose the back panel
Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
With a plastic spudger, carefully remove the back panel by prying each corner off individually
Slowly pick up the panel and set it aside
The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
To remove the old battery, slightly lift the bottom edge of the battery with your hands
Now slowly pull the battery towards you to fully detach the battery
Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
Lift and hold the hard drive in your left hand.
Use your right hand to grab hold of the black wire connector attached on the right of the hard drive.
Carefully pull the connector away from the hard drive to completely disconnect from the laptop.
Unscrew and remove the 2 of the 7mm Phillips head screws holding the cooling fan in place.
Hold the cooling fan with one hand.
With the other hand, grab hold of the part of the copper heat sink that is attached to the cooling fan.
Carefully pull the cooling fan away from the attached part so that it becomes fully disconnected.
Unplug antenna cables located at the top left corner.
Unplug daughter board located to the bottom left of the cooling fan.
Find the heat sink (copper colored metal).
Use Phillips 0 screwdriver to loosen the 3 of the 3mm Phillips head screws from the heat sink.
Remove the heat sink
Use Phillips 0 screwdriver to unscrew the 2 of the 3mm screws holding the LCD cable bracket in place.
Remove the LCD cable bracket.
Unplug LCD and touchscreen cables.
Use Phillips 0 screwdriver to unscrew and remove the 3 of the 7mm screws from the LCD display.
Open the laptop so that the screen and keyboard are face down on the desk.
Carefully disconnect the LCD display by lifting the screen upward and away from the bottom half of the laptop.
Use the plastic spudger to disconnect the mini circuit board from the casing.
Disconnect the small wires connecting the screen to the casing.
Remove the loose wiring from the perimeter of the screen.
Gently separate the LCD screen from the laptop casing.
