Introduction
This guide will show you how to replace your device's battery without any hiccups. You will need one Phillips #0 screwdriver and one plastic spudger.
First flip over the laptop to expose the back panel
Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
With a plastic spudger, carefully remove the back panel by prying each corner off individually
Slowly pick up the panel and set it aside
The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
To remove the old battery, slightly lift the bottom edge of the battery with your hands
Now slowly pull the battery towards you to fully detach the battery
