Dell Inspiron 13-7352 Memory Module (RAM) Replacement
  1. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: step 1, image 3 of 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: step 2, image 1 of 2 Dell Inspiron 13-7352 Memory Module (RAM) Replacement: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: step 3, image 1 of 1
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): step 4, image 1 of 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): step 4, image 2 of 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): step 4, image 3 of 3
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
  5. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: step 5, image 1 of 1
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
4 other people completed this guide.
Chase Sparkman
506 Reputation
2 Guides authored
4 Comments
Hello is the procedure same for 7353 ? can the ram be upgraded to 16GB. it currently has 8GB
Ali M - Reply
Hi! Same questions as Ali M: Is the procedure same for 7353 ? can the ram be upgraded to 16GB: It currently has 8GB and I'd like to upgrade it to 16 GB.
Roberto de Souza Santos - Reply
Did anyone ever get an answer if it can take 16 GB of RAM?
Robert Iversen - Reply
A 16GB RAM would work but it should be a single sodimm module like CT204864BF160B
Hochan Son - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 3,229
