Introduction
Use this guide if you are having problems with the brightness of the display.
Lay the monitor screen-down so the back screws are exposed.
Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
Locate the two holes on the bottom of the monitor.
Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
Continue prying along the entire edge of the monitor.
When finished prying, the plastic will partially fall away from the rest of the monitor.
While holding the frames together, carefully flip the monitor over so it faces screen down.
Gently lift and remove remove the rear case from the monitor.
Locate the green interface button board.
Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
Lift the monitor interior away from the front cover.
With the monitor facing down, remove the two 5.81 mm Phillip #2 screws on the right side of the metal casing.
With the monitor still facing down, remove the two 5.81 mm Phillip #2 screws on the left side of the casing.
Remove the three 7.69 mm Phillip #2 screws from the inverter board.
Remove the two 7.69 mm Phillip #2 grounding screws from the wire with the black connector.
Gently pull the inverter board away from the case.
There is a wire connecting the motherboard to the inverter board. Squeeze both sides of the connector and pull to remove it from the socket.
There is another wire connecting the button board to the inverter board. Remove the second white wire connector.
A third wire connects the inverter board to the screen circuit board. Remove the black wire connector.
The inverter board can now be fully removed.
