Dell Dimension 4600 Side Panel Replacement
  1. Dell Dimension 4600 Side Panel Replacement, Side Panel: step 1, image 1 of 1
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 Side Panel Replacement: step 2, image 1 of 1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 Side Panel Replacement: step 3, image 1 of 1
    • Grab the edge of the panel and slide it away from the case until it is removed.
Daniel Crawford
1,021 Reputation
2 Guides authored
Cal Poly, Team 6-10, Regan Fall 2011 Member of Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Members
11 Guides authored
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 32
All Time: 21,813
