Installing Dell Dimension 4600 Fan
  1. Installing Dell Dimension 4600 Fan, Side Panel: step 1, image 1 of 1
    • Locate the case cover latch on the back of the computer.
  2. Installing Dell Dimension 4600 Fan: step 2, image 1 of 1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Installing Dell Dimension 4600 Fan: step 3, image 1 of 1
    • Grab the edge of the panel and slide it away from the case until it is removed.
  4. Installing Dell Dimension 4600 Fan, Fan: step 4, image 1 of 1
    • Lay the computer flat on it's side so that you are looking down at all of the components.
    • Locate the fan and its black, red, and white power cable.
  5. Installing Dell Dimension 4600 Fan: step 5, image 1 of 1
    • Follow the power cable to the motherboard connection and remove it by pressing down on the clip.
  6. Installing Dell Dimension 4600 Fan: step 6, image 1 of 1
    • Locate the release clip on the side of the fan and hold it down with your thumb.
  7. Installing Dell Dimension 4600 Fan: step 7, image 1 of 1
    • While holding the release clip down, look on the outside of the case where the fan lies.
    • Using the four black notches as a reference, slide the fan towards the open side releasing the fan.
Tim
76 Reputation
1 Guide authored
Cal Poly, Team 6-10, Regan Fall 2011 Member of Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Members
11 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 5,921
