Dell Chromebook 3180 Charging Port Replacement
  1. Dell Chromebook 3180 Charging Port Replacement, Remove Bottom Cover / Shell: step 1, image 1 of 2 Dell Chromebook 3180 Charging Port Replacement, Remove Bottom Cover / Shell: step 1, image 2 of 2
    • Remove the 7 screws from the back cover with a Phillips #0 screwdriver
    • Once all 7 screws have been removed, you can start to pry apart the back cover with your Plastic Blade or your fingers. (See pic)
    • Using a Phillips #0, remove the 2 screws from the right side hinge.
    • Lift the chromebook base in order to force the hinge in an upward position. This will provide you enough room to remove the charging port.
    • Remove the 2 charging port screws
    • Unplug the charging port connector from the Motherboard
    • Disconnect the charging port connector from the motherboard.
    • Replace the charging port if needed by connecting the new charging port connector to the motherboard.
    • Using a Phillips#0, replace the 2 charging port screws.
    • Reset the right side hinge back into place by pressing down so the hinge is flush against the chromebook base.
    • Secure with the 2 screws using your phillips #0.
  2. Dell Chromebook 3180 Charging Port Replacement, Replace Bottom Cover: step 5, image 1 of 1
    • Secure all 7 screws with a Phillips #0
4 other people completed this guide.
Jon
3,921 Reputation
22 Guides authored
One Comment
Hey Party Person, nice job. I believe you might be the greatest tech to ever hold a screw driver. This song is for you https://youtu.be/ItWIYcD6jas
foshizol - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 1,073
