Dell Chromebook 3100 2-in-1 Motherboard Replacement
  1. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Back Cover: step 1, image 1 of 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Back Cover: step 1, image 2 of 2
    • First of all, you have to shut down your Chromebook completely, unplug the power cable and remove any accessories like a mouse or USB drive.
    • Turn the Chromebook upside down so the bottom panel is facing up.
    • Use your Phillips #1 screwdriver to take out all 5mm screws from the bottom case, keep the screws safe, they’re easy to lose!
  2. Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 2, image 1 of 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 2, image 2 of 2
    • Use the opening tool to pry the back cover off of the device.
    • Gently insert your plastic prying tool between the bottom cover and the keyboard deck.
    • Work your way around the edges until the case starts to pop open.
    • Lift off the bottom cover carefully.
  3. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Battery: step 3, image 1 of 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Battery: step 3, image 2 of 2
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 4, image 1 of 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 4, image 2 of 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 4, image 3 of 3
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 5, image 1 of 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 5, image 2 of 2
    • Carefully remove the battery from the device.
  6. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Speaker: step 6, image 1 of 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Speaker: step 6, image 2 of 2
    • Remove adhesive tape that secures the speaker cable.
    • Disconnect the speaker cable from the connector on the system board.
  7. Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 7, image 1 of 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 7, image 2 of 2
    • Remove the speaker cable from the retention clips.
  8. Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 8, image 1 of 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 8, image 2 of 2
    • Lift and remove the speakers from the device.
  9. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Motherboard: step 9, image 1 of 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Motherboard: step 9, image 2 of 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Motherboard: step 9, image 3 of 3
    • Disconnect the keyboard cable.
  10. Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 10, image 1 of 1
    • Disconnect the two input-output board cables from the motherboard.
  11. Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 11, image 1 of 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 11, image 2 of 2
    • Disconnect the touchpad cable.
    • Disconnect the USB Type-C power cable.
  12. Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 12, image 1 of 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 12, image 2 of 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 12, image 3 of 3
    • Remove the single 3 mm screw that secures the WLAN bracket to the system board using a Phillips #1 screwdriver.
    • Lift the WLAN bracket from the system board.
    • After lifting the bracket, carefully unplug the two coaxial cables.
  13. Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 13, image 1 of 1
    • Remove the single 4 mm screw that secures the eDP bracket to the motherboard using a Phillips #1 screwdriver.
    • Remove the eDP bracket.
  14. Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 14, image 1 of 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 14, image 2 of 2
    • Disconnect the display cable from the motherboard by using a plastic opening pick.
  15. Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 15, image 1 of 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 15, image 2 of 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 15, image 3 of 3
    • Remove the five 4 mm screws that secure the motherboard using a Phillips #1 screwdriver.
  16. Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 16, image 1 of 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: step 16, image 2 of 2
    • Lift and remove the motherboard from the computer.
6 other people completed this guide.
Muhammad Ali
355 Reputation
2 Guides authored
Gateway, Team 1-1, Pee Fall 2021 Member of Gateway, Team 1-1, Pee Fall 2021
GCC-PEE-F21S1G1
5 Members
5 Guides authored
1 Guide Comment
Any idea how to use the USB repair shim? Dell's guide didn't help
Josie - Reply
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 92
All Time: 2,865
