Dell Chromebook 11 3180 Back Cover Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Dell Chromebook 11 3180 Back Cover  Replacement, Back Cover: step 1, image 1 of 1
    • Set your laptop upside down on your work space.
  2. Dell Chromebook 11 3180 Back Cover  Replacement: step 2, image 1 of 1
    • Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
  3. Dell Chromebook 11 3180 Back Cover  Replacement: step 3, image 1 of 1
    • Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • These screws will stay attached to the back cover, so just loosen them until they rattle around.
  4. Dell Chromebook 11 3180 Back Cover  Replacement: step 4, image 1 of 1
    • Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • If you have trouble prying a particular part of the back cover off, make sure that the nearest screws are fully loosened.
  5. Dell Chromebook 11 3180 Back Cover  Replacement: step 5, image 1 of 1
    • Using your hands, pull the back cover fully off of the body of the computer.
Devon Paul
1,206 Reputation
6 Guides authored
Cal Poly, Team S22-G1, Livingston Spring 2017 Member of Cal Poly, Team S22-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G1
4 Members
8 Guides authored
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 8
All Time: 100
