Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Community-Contributed Guide
Introduction
Go to step 1 ↓In this guide, we will show you how to remove and replace the Memory Module.
Tools
Disconnect the battery-pack cable from the connector on the system board.
Loosen the two captive screws that secure the battery pack to the computer base.
Using the pull-tab, lift the battery pack off the computer base.
Place the NEW battery pack in the battery bay and tighten the two captive screws that secure the battery pack to the computer base.
Connect the battery-pack cable to the connector on the system board.
Loosen the two captive screws that secure the memory-module cover to the computer base.
Slide the tabs on the memory-module cover out of the slots on the computer base.
Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
Align the notch in the NEW memory module with the tab in the memory- module connector.
Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Slide the tabs on the memory-module cover into the slots on the computer base and lower the memory-module cover into place.
Tighten the two captive screws that secure the memory-module cover to the computer base.
