Dell Alienware M11x R3 Display Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Dell Alienware M11x R3 Display Assembly  Replacement, Disconnect the Antenna Cables: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • Disconnect the antenna cables from the Mini-Card(s).
      Ask FixBot
    2. Dell Alienware M11x R3 Display Assembly  Replacement, Note the Routing: step 2, image 1 of 1
      • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the computer base.
      Ask FixBot
    3. Dell Alienware M11x R3 Display Assembly  Replacement, Turn the Computer Over: step 3, image 1 of 1
      • Turn the computer over and open the display as far as possible.
      Ask FixBot
    4. Dell Alienware M11x R3 Display Assembly  Replacement, Disconnect the Display Cable: step 4, image 1 of 1
      • Pull the pull-tab to disconnect the display cable from the connector on the system board.
      Ask FixBot
    5. Dell Alienware M11x R3 Display Assembly  Replacement, Remove the Screws: step 5, image 1 of 1
      • Remove the four screws that secure the display assembly to the computer base.
      Ask FixBot
    6. Dell Alienware M11x R3 Display Assembly  Replacement, Sliding the Cables Out: step 6, image 1 of 1
      • Gently slide the Mini-Card antenna cables out through the slot on the computer base.
      Ask FixBot
    7. Dell Alienware M11x R3 Display Assembly  Replacement, Lifting the Display Assembly: step 7, image 1 of 1
      • Lift the display assembly off the computer.
      Ask FixBot
      • Slide the antenna cables in through the slot on the computer base.
      Ask FixBot
    8. Dell Alienware M11x R3 Display Assembly  Replacement, Positioning the Display Assembly: step 9, image 1 of 1
      • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
      Ask FixBot
    9. Dell Alienware M11x R3 Display Assembly  Replacement, Connect the Display Cable: step 10, image 1 of 1
      • Connect the display cable to the connector on the system board.
      Ask FixBot
    10. Dell Alienware M11x R3 Display Assembly  Replacement, Routing the Antenna Cables: step 11, image 1 of 1
      • Turn the computer over and route the Mini-Card antenna cables through the routing guides on the computer base.
      Ask FixBot
    11. Dell Alienware M11x R3 Display Assembly  Replacement, Connect the Antenna Cables: step 12, image 1 of 1
      • Connect the Mini-Card antenna cables to the Mini-Card(s).
      Ask FixBot
Terrence15
80,137 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,277 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 96
