Introduction
In this guide, we will be showing you how to remove and replace the Memory Module.
To remove memory module(s) from connectors DIMM3 and DIMM4, go to step 3.
To remove memory module(s) from connectors DIMM1 and DIMM2: Remove the palm rest. See"Removing the Palm Rest" on page 39.
Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
Align the notch on the NEW memory module with the tab on the memory-module connector.
Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
