Dell Alienware 15 R3 Cover Assembly Replacement
  1. Dell Alienware 15 R3 Cover Assembly Replacement, Back Case: step 1, image 1 of 3 Dell Alienware 15 R3 Cover Assembly Replacement, Back Case: step 1, image 2 of 3 Dell Alienware 15 R3 Cover Assembly Replacement, Back Case: step 1, image 3 of 3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Cover Assembly Replacement: step 2, image 1 of 1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Cover Assembly Replacement, Cover Assembly: step 3, image 1 of 1
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Cover Assembly Replacement: step 4, image 1 of 2 Dell Alienware 15 R3 Cover Assembly Replacement: step 4, image 2 of 2
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Cover Assembly Replacement: step 5, image 1 of 3 Dell Alienware 15 R3 Cover Assembly Replacement: step 5, image 2 of 3 Dell Alienware 15 R3 Cover Assembly Replacement: step 5, image 3 of 3
    • Use a Phillips #00 screwdriver to remove 10 screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 27
All Time: 806
