Dell Alienware 13 Solid-State Drive (SSD) Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
    • CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
  1. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Pull Tab: step 2, image 1 of 1
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  2. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Disconnecting the State Drive: step 3, image 1 of 1
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  3. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Remove Screws: step 4, image 1 of 1
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  4. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Solid-State Drive Assembly Lift: step 5, image 1 of 2 Dell Alienware 13 Solid-State Drive (SSD) Replacement, Solid-State Drive Assembly Lift: step 5, image 2 of 2
    • Lift the solid-state drive assembly off the computer base.
    • Make sure the screws are off the solid-state assembly.
  5. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Slide and Lift: step 6, image 1 of 1
    • Slide and lift the solid-state drive off the solid-state assembly.
  6. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Replacing the Solid-State Drive: step 7, image 1 of 1
    • Slide the new solid-state drive into the solid-state drive assembly.
  7. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Replace the Screw: step 8, image 1 of 1
    • Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
  8. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Screw Align: step 9, image 1 of 1
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  9. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Screw Replacement: step 10, image 1 of 1
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  10. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Connecting the Drive: step 11, image 1 of 1
    • Connect the solid-state drive cable to the system board.
  11. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Aligning Screws: step 12, image 1 of 1
    • Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  12. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Replacing Screws: step 13, image 1 of 1
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
Finish Line
Terrence15
79,131 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,986 Guides authored
One Comment
Hi there. Could I have a link to the full service manual you got this from? Thanks.
Aiden - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 202
