Dell Inspiron 13-5368 Wifi Adapter Replacement
  1. Dell Inspiron 13-5368 Wifi Adapter Replacement, Wifi Adapter: step 1, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the 9.6 mm screws securing the back plate of the laptop.
  2. Dell Inspiron 13-5368 Wifi Adapter Replacement: step 2, image 1 of 1
    • Use a prying tool to remove the back plate.
  3. Dell Inspiron 13-5368 Wifi Adapter Replacement: step 3, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws holding the battery in place.
  4. Dell Inspiron 13-5368 Wifi Adapter Replacement: step 4, image 1 of 1
    • Disconnect the cable connecting the battery to the motherboard, and then remove the battery
  5. Dell Inspiron 13-5368 Wifi Adapter Replacement: step 5, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the 3mm screw and the metal bracket that holds the network adapter card in place.
  6. Dell Inspiron 13-5368 Wifi Adapter Replacement: step 6, image 1 of 2 Dell Inspiron 13-5368 Wifi Adapter Replacement: step 6, image 2 of 2
    • Pull out the network card.
    • To completely remove the network card, disconnect the two cords (white and black) from the adapter card. White on 1 and Black on 2.
Raj Dhavalikar
136 Reputation
1 Guide authored
IUPUI, Team S4-G4, Wilson Fall 2018 Member of IUPUI, Team S4-G4, Wilson Fall 2018
IUPUI-WILSON-F18S4G4
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 44
All Time: 1,456
