Introduction
Go to step 1 ↓The DeWalt D26451's brake function may go bad after heavy usage.
In this guide, we will be teaching you how to replace the brake on the D26451. You can purchase a replacement brake here.
Tools
T15 Torx Screwdriver$7.99
Insert the 60 mm extension into the screw driver which has the t15 torx bit installed in order to make a t-handle grip.
Turn the screwdriver counter-clockwise to loosen all three screws in the disc pad.
Loosen and remove the three screws on the bottom of the sander that holds the disc pad to the bottom of the sander.
