DeWalt DC970 Motor Replacement
  1. DeWalt DC970 Motor Replacement, Battery: step 1, image 1 of 1
    • Compress the buttons on either side of the battery and lift the drill away from battery.
  2. DeWalt DC970 Motor Replacement: step 2, image 1 of 1
    • Remove battery from drill.
  3. DeWalt DC970 Motor Replacement, Drill Assembly: step 3, image 1 of 2 DeWalt DC970 Motor Replacement, Drill Assembly: step 3, image 2 of 2
    • Remove the eight 16 mm, Torx Security #15 screws.
  4. DeWalt DC970 Motor Replacement: step 4, image 1 of 1
    • Lay the drill on its side and gently lift the top half off it.
  5. DeWalt DC970 Motor Replacement, Motor: step 5, image 1 of 1
    • Lift drill mechanism out of the shell.
    • Desolder the red and black wires from the motor.
    • Learn more about soldering here.
  6. DeWalt DC970 Motor Replacement: step 6, image 1 of 1
    • Slightly twist and pull motor away from the clutch.
  7. DeWalt DC970 Motor Replacement: step 7, image 1 of 1
    • When installing the replacement motor into the clutch make sure you correctly align the gears in order to assure that the motor is properly fitted to the clutch.
2 other people completed this guide.
Jonathan Hamel
633 Reputation
4 Guides authored
3 Comments
Unplug the wires from the trigger switch....don't unsolder.
New motor comes with wires.
allen.anderson1 - Reply
Thanks for the heads up on the wires
Daniel Randall - Reply
Is there a fix to replace brushes?
pmac086 - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 47
All Time: 6,535
