De'Longhi EC155 Top Panel Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. De'Longhi EC155 Top Panel Replacement, Water Reservoir: step 1, image 1 of 2 De'Longhi EC155 Top Panel Replacement, Water Reservoir: step 1, image 2 of 2
    • Flip open the top panel to reveal water reservoir.
    • Grab the water reservoir by the handle and lift out.
  2. De'Longhi EC155 Top Panel Replacement, Top Panel: step 2, image 1 of 1
    • Before flipping the device, removed the black container and grill.
    • Flip the device on its head, front end facing you.
    • Using the Phillips #2 unscrew the two 52 mm screws found underneath the top portion of the device.
  3. De'Longhi EC155 Top Panel Replacement: step 3, image 1 of 1
    • Flip the device back to its proper orientation.
    • Using the Phillips #2 screwdriver remove the two 52 mm screws found on the lip next to the reservoir.
  4. De'Longhi EC155 Top Panel Replacement: step 4, image 1 of 2 De'Longhi EC155 Top Panel Replacement: step 4, image 2 of 2
    • Insert the two plastic opening tools beneath the top knob.
    • Use the two plastic opening tools as leverage to lift the top knob off.
  5. De'Longhi EC155 Top Panel Replacement: step 5, image 1 of 1
    • Grasp the lid firmly with both hands.
    • Pull mightily with both hands away from the device.
    • If you hear a slight snapping sound, it is supposed to do that.
  6. De'Longhi EC155 Top Panel Replacement: step 6, image 1 of 2 De'Longhi EC155 Top Panel Replacement: step 6, image 2 of 2
    • Use a plastic opening tool to push in the slot on the back panel while lifting.
    • Similarly, reach into where the reservoir used to be and insert a plastic spudger underneath the inside panel.
    • We recommend to not use your fingers for this step because there is a chance they will be pinched.
  7. De'Longhi EC155 Top Panel Replacement: step 7, image 1 of 2 De'Longhi EC155 Top Panel Replacement: step 7, image 2 of 2
    • You are now ready to lift the top off.
    • Place one hand near the back, the other at the front, and lift.
    • You may want to lift the front and back individually by pulling one a little off the part before the other. Afterwards, lifting the top off entirely will be easier.
David Griffith
1,471 Reputation
9 Guides authored
Cal Poly, Team 4-2, Maness Fall 2015 Member of Cal Poly, Team 4-2, Maness Fall 2015
CPSU-MANESS-F15S4G2
4 Members
25 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 65
