Daylight Running Lamp Replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
40
Past 30 Days:
156
All Time:
756
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide learn how to change the daytime running lamp in a Kia Soul 2017. These lights are important for visibility of the vehicle during the day and their proper functioning is essential for road safety. The steps are very simple, anyone can Do them. Make sure you have the right bulb.
    1. Daylight Running Lamp Replacement, Locating and Removing the Bulb: step 1, image 1 of 2 Daylight Running Lamp Replacement, Locating and Removing the Bulb: step 1, image 2 of 2
      • Open the hood of the car and locate the running light, (red circle) at the end of the headlamp housing. Look for the bulb holder, a piece of plastic or metal that holds the bulb in place inside the headlight housing.
      • Using your fingers, slightly rotate (orange arrows) the plastic piece bulb holder, unlocking it. Remove it along with the bulb.
      Ask FixBot
      • Press the bulb down slightly and twist it to remove it from the holder. Replace the bulb by doing the same: press the new bulb down and twist it (in the opposite direction) to secure it in the holder.
      • Finally, insert the holder with the new bulb back into the headlight, turning back to it's 'locked' position. Remember the position of the holder when removing it, so that it can be reinserted in the correct position
      • Ready! You have changed the running lamp yourself and acquired knowledge.
      Ask FixBot
It is recommended you verify the replacement bulb is appropriate for your vehicle. It's possible they vary by model. Please consult a workshop, specialized center, or a trusted website.
Special thanks to these translators:
es en
100%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
El Mécanico Español
562 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 40
Past 30 Days: 156
All Time: 756
