Introduction
Designed as a low cost tablet for students in India, Datawind's Ubislate 7CI sells for about $35, to students in India, with the price subsidized by the government. The device is 7.2 by 4.8 by .4 inches (HWD) and weighs 11.2 ounces.
Be sure to repair your device on a clean surface so you are less likely to lose small parts.
Run your prying tool along the front edge of the device to pop off the front cover.
Once the halves are separated your device should look like this.
(HINT: be careful of the device's small wiring when separating the two halves.
Remove the black tape.
Your tablet should look like photo 3 after you have removed the tape.
Pry off the battery, be careful not to break the battery.
Use soldering iron or gun to remove the battery from both its attachment points.
Insert your replacement battery in the same spot as the old battery.
Tape battery into place.
Solder the new battery to the connection points.
Press the back cover on firmly till it clicks
