15mm compression nut from a water isolator valve, you can get these nuts from any plumbing or diy shop.
Simply use the new metal nut, as you can see from the picture the plastic one cracked, I tried to tape it but that did not work. Metal one is much better, just make sure you dont over tighten and break the plastic threads.
Final picture, all done and working properly.
Almost done!
