Introduction
This guide shows the necessary steps for removing the motherboard from a DOSS SoundBox.
This repair may be needed if your DOSS SoundBox has static, intermittent connection issues or is unable to play music.
Some soldering skills are required as two contact points on the motherboard must be removed by soldering to uninstall the board.
There is also some adhesive holding the motherboard in place, so caution is recommended during removal to prevent breaks or cracks.
Use a small plastic opening tool to gently lift the side of the grille.
Gently slide the tool to the front of the speaker.
Repeat the process on the bottom of the grille.
Gently pull the grille off of the speaker enclosure.
Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
Use a soldering iron to de-solder the two speaker wires from the speaker itself.
The speakers are ready to be removed and replaced.
Use a JIS #00 screwdriver to remove the four 3/32" screws that attach the base-plate to the speaker enclosure.
Use a JIS #1 screwdriver to remove the six 3/32" screws marked with a red circle.
Remove the two 1/16" screws marked with orange circles using a JIS #000 screwdriver.
Remove the six 3/32" screws marked with red circles using a JIS #00 screwdriver.
Remove the larger 3/32" screw indicated by an orange circle using a JIS #1 screwdriver.
Once the screws are removed, gently lift the top (where the touch controls are) off of the speaker.
Remove the two 3/32" screws that attach the motherboard to the battery compartment using a JIS #00 screwdriver.
Use your fingers or a pair of tweezers to remove the clip holding the ribbon connector in place. The connector is indicated with an orange marker.
Find the speaker connector, indicated by a yellow circle, and using your fingers disconnect it.
Locate and remove the two 3/32" screws, indicated by red markers, that fix the motherboard to the speaker enclosure.
Using the plastic opening tool, gently begin to pry the circuit card away from the speaker enclosure.
Using your fingers, you can now remove the motherboard.
