DOSS SoundBox Battery Replacement
  1. DOSS SoundBox Battery Replacement, Battery: step 1, image 1 of 2 DOSS SoundBox Battery Replacement, Battery: step 1, image 2 of 2
    • Use a JIS #00 screwdriver to remove the four 3/32" screws that attach the base-plate to the speaker enclosure.
    • Use a magnetic mat to prevent the loss of screws.
  2. DOSS SoundBox Battery Replacement: step 2, image 1 of 2 DOSS SoundBox Battery Replacement: step 2, image 2 of 2
    • Use a JIS #1 screwdriver to remove the six 3/32" screws marked with a red circle.
    • Remove the two 1/16" screws marked with orange circles using a JIS #000 screwdriver.
  3. DOSS SoundBox Battery Replacement: step 3, image 1 of 1
    • Remove the six 3/32" screws marked with red circles using a JIS #00 screwdriver.
    • Remove the larger 3/32" screw indicated by an orange circle using a JIS #1 screwdriver.
    • Once the screws are removed, gently lift the top (where the touch controls are) off of the speaker.
  4. DOSS SoundBox Battery Replacement: step 4, image 1 of 1
    • De-solder the connections from the battery to the circuit board.
    • If you do not already have a replacement battery, you can purchase one here.
    Thank you. It's 2023 and I needed to get my speaker up and running again.
    Big Kev - Reply
3 other people completed this guide.
One Comment
What could be the cause that the box works perfectly on low volume, but as soon as I raise the volume the box shuts down?
Thanks so much for your work here. :)
Milad Etemadi - Reply
Past 24 Hours: 3
Past 7 Days: 39
Past 30 Days: 191
All Time: 11,010
