Shop the Holiday Gift Guide
DOPO 10.1 Tablet Battery Replacement
Views: 3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
34
Past 30 Days:
100
All Time:
3,045
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
For this project you will need to have the knowledge, and tools necessary to solder. The following link gives instructions on how to solder. How To Solder and Desolder Connections
Tools
    1. DOPO 10.1 Tablet Battery Replacement, Remove Back: step 1, image 1 of 3 DOPO 10.1 Tablet Battery Replacement, Remove Back: step 1, image 2 of 3 DOPO 10.1 Tablet Battery Replacement, Remove Back: step 1, image 3 of 3
      • Take plastic opening tools, and find a spot on the back of tablet to lift the back plate. Once back is lifted enough, remove the back of the tablet carefully with fingers
      Ask FixBot
    2. DOPO 10.1 Tablet Battery Replacement, Locate Battery: step 2, image 1 of 1
      • Locate battery, and examine wires connected to battery.
      Ask FixBot
    3. DOPO 10.1 Tablet Battery Replacement, Remove Battery: step 3, image 1 of 3 DOPO 10.1 Tablet Battery Replacement, Remove Battery: step 3, image 2 of 3 DOPO 10.1 Tablet Battery Replacement, Remove Battery: step 3, image 3 of 3
      • Carefully remove battery without putting any strain on connected wires. The battery is held to the tablet with adhesive, so be careful not to jerk the battery when it becomes loose.
      Ask FixBot
    4. DOPO 10.1 Tablet Battery Replacement, Disconnect Wires: step 4, image 1 of 3 DOPO 10.1 Tablet Battery Replacement, Disconnect Wires: step 4, image 2 of 3 DOPO 10.1 Tablet Battery Replacement, Disconnect Wires: step 4, image 3 of 3
      • Use a soldering iron to carefully remove wires from motherboard. Then remove battery.
      Ask FixBot
Author
with
Kaitlyn Hayes
414 Reputation
4 Guides authored
USF Tampa, Team 5-2, Brown Winter 2015 Member of USF Tampa, Team 5-2, Brown Winter 2015
USFT-BROWN-W15S5G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 34
Past 30 Days: 100
All Time: 3,045
