DJI Mavic Pro Upper Shell Replacement
  1. DJI Mavic Pro Upper Shell Replacement, Battery: step 1, image 1 of 3 DJI Mavic Pro Upper Shell Replacement, Battery: step 1, image 2 of 3 DJI Mavic Pro Upper Shell Replacement, Battery: step 1, image 3 of 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro Upper Shell Replacement, Upper Shell: step 2, image 1 of 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro Upper Shell Replacement: step 3, image 1 of 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro Upper Shell Replacement: step 4, image 1 of 1
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro Upper Shell Replacement: step 5, image 1 of 1
    • Remove the four 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  6. DJI Mavic Pro Upper Shell Replacement: step 6, image 1 of 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro Upper Shell Replacement: step 7, image 1 of 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
Mondona Behroozian
1,552 Reputation
2 Guides authored
Cal Poly, Team S17-G3, White Fall 2018 Member of Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 27
All Time: 5,167
