DJI Matrice 210 Removal of Upper Shell
  1. DJI Matrice 210 Removal of Upper Shell, Removal of Upper Shell: step 1, image 1 of 2 DJI Matrice 210 Removal of Upper Shell, Removal of Upper Shell: step 1, image 2 of 2
    • First use the 2mm hex bit to remove these four screws on the underside of the aircraft
    • To gain access to the front two screws, it may be necessary to remove the three pictured screws from the gimbal mount
    • Use a sorting device such as a tray or baggies to separate and label screws from step-to-step. This will make the reassembly process easier
    Ask FixBot
  2. DJI Matrice 210 Removal of Upper Shell: step 2, image 1 of 1
    • Use the 2mm hex bit to remove the silver screws that secure the landing gear mounts
    • Remove the landing gear mounts
    Ask FixBot
  3. DJI Matrice 210 Removal of Upper Shell: step 3, image 1 of 1
    • Use the 1.5mm hex bit to remove these two screws from the port cover
    Ask FixBot
  4. DJI Matrice 210 Removal of Upper Shell: step 4, image 1 of 2 DJI Matrice 210 Removal of Upper Shell: step 4, image 2 of 2
    • Use the 2mm hex bit to remove these four screws in order to detach this section of the gimbal mount
    • Using a plastic tool, pry off the front cover/screen. This may require some force to break the seal. Work slowly around the edge of the cover to avoid breaking the plastic.
    • After removing the cover, you can now remove the upper shell. Start by inserting your plastic wedge in the seam that was covered by the front cover. Slowly work the wedge around the body of the aircraft to pry the cover off.
    Ask FixBot
  5. DJI Matrice 210 Removal of Upper Shell: step 5, image 1 of 3 DJI Matrice 210 Removal of Upper Shell: step 5, image 2 of 3 DJI Matrice 210 Removal of Upper Shell: step 5, image 3 of 3
    • To access the strobe, start by unplugging the pictured cord from the circuitboard
    • Remove the 4 circled screws with a 1.5mm hex bit
    • To resecure the strobe, a small amount of superglue was applied using a small brush. Replacement of the upper shell may be necessary depending on the extent of the damage
    • For reassembly, follow the steps in reverse order. Ensure that the upper shell is fully snapped into place before inserting any screws. Conduct a boot up and test flight to ensure proper reassembly
    Ask FixBot
Kendrick Wittmer
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 37
All Time: 184
