DBPOWER RD-810 Magnifier Replacement
    1. DBPOWER RD-810 Magnifier Replacement, Top Cover: step 1, image 1 of 2 DBPOWER RD-810 Magnifier Replacement, Top Cover: step 1, image 2 of 2
      • Make sure the projector is unplugged before starting
      • Place the projector upside down to access the screws on the bottom.
      • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
      Ask FixBot
    2. DBPOWER RD-810 Magnifier Replacement: step 2, image 1 of 1
      • Flip the projector over and then remove the cover by lifting it up.
      Ask FixBot
    1. DBPOWER RD-810 Magnifier Replacement, Motherboard and LED Bulb: step 3, image 1 of 3 DBPOWER RD-810 Magnifier Replacement, Motherboard and LED Bulb: step 3, image 2 of 3 DBPOWER RD-810 Magnifier Replacement, Motherboard and LED Bulb: step 3, image 3 of 3
      • Remove the three 6mm PH2 phillips head screws.
      • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
      Ask FixBot
    2. DBPOWER RD-810 Magnifier Replacement: step 4, image 1 of 3 DBPOWER RD-810 Magnifier Replacement: step 4, image 2 of 3 DBPOWER RD-810 Magnifier Replacement: step 4, image 3 of 3
      • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
      • Keep the connector parallel to the mother board to avoid breaking the solder connection.
      • Lift the motherboard up and place it out of the way.
      Ask FixBot
    3. DBPOWER RD-810 Magnifier Replacement: step 5, image 1 of 3 DBPOWER RD-810 Magnifier Replacement: step 5, image 2 of 3 DBPOWER RD-810 Magnifier Replacement: step 5, image 3 of 3
      • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
      • Lift the aluminum heat sink up to remove it from the projector.
      • The motherboard is already removed in this step.
      Ask FixBot
    1. DBPOWER RD-810 Magnifier Replacement, Magnifier: step 6, image 1 of 3 DBPOWER RD-810 Magnifier Replacement, Magnifier: step 6, image 2 of 3 DBPOWER RD-810 Magnifier Replacement, Magnifier: step 6, image 3 of 3
      • Remove the two 9mm PH2 phillips head screws.
      • Lift the Magnifier out of the projector.
      Ask FixBot
John Russell
941 Reputation
9 Guides authored
USF Tampa, Team S5-G3, Eyestone Spring 2018 Member of USF Tampa, Team S5-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S5G3
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 38
All Time: 639
