D-Link HD Wi-Fi Camera Light Sensor Replacement
    1. D-Link HD Wi-Fi Camera Light Sensor Replacement, Motherboard: step 1, image 1 of 1
      • Place the camera upwards between your thumb and first finger.
      • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
      • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
      Ask FixBot
    2. D-Link HD Wi-Fi Camera Light Sensor Replacement: step 2, image 1 of 2 D-Link HD Wi-Fi Camera Light Sensor Replacement: step 2, image 2 of 2
      • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
      • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
      Ask FixBot
    3. D-Link HD Wi-Fi Camera Light Sensor Replacement: step 3, image 1 of 2 D-Link HD Wi-Fi Camera Light Sensor Replacement: step 3, image 2 of 2
      • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
      • Then (gently!) remove the motherboard and the lens with your fingers.
      Ask FixBot
    1. D-Link HD Wi-Fi Camera Light Sensor Replacement, Microphone: step 4, image 1 of 1
      • To remove the front cover, place index finger in the center and pull away from the frame. This may take a little effort, but should not require an opening tool.
      Ask FixBot
    2. D-Link HD Wi-Fi Camera Light Sensor Replacement: step 5, image 1 of 2 D-Link HD Wi-Fi Camera Light Sensor Replacement: step 5, image 2 of 2
      • After the cover is removed, unscrew the two Phillips #00 5.0mm screws. Then the board should slide right out.
      Ask FixBot
    1. D-Link HD Wi-Fi Camera Light Sensor Replacement, Light Sensor: step 6, image 1 of 1
      • The light sensor is located at the bottom of the board.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 66
All Time: 2,105
