D-Link DIR-890L Case Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. D-Link DIR-890L Case Removal, Case: step 1, image 1 of 3 D-Link DIR-890L Case Removal, Case: step 1, image 2 of 3 D-Link DIR-890L Case Removal, Case: step 1, image 3 of 3
      • Peel off the four rubber rectangular feet with your fingers.
      • The feet may be hard to remove. Apply additional force if necessary.
      Ask FixBot
    2. D-Link DIR-890L Case Removal: step 2, image 1 of 3 D-Link DIR-890L Case Removal: step 2, image 2 of 3 D-Link DIR-890L Case Removal: step 2, image 3 of 3
      • Unscrew the 5mm screws in each corner using the Phillips #1 screwdriver.
      Ask FixBot
    3. D-Link DIR-890L Case Removal: step 3, image 1 of 3 D-Link DIR-890L Case Removal: step 3, image 2 of 3 D-Link DIR-890L Case Removal: step 3, image 3 of 3
      • Wedge the opening tool between the red top panel and the gray bottom panel.
      • Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
      Ask FixBot
Rachel Shaw
553 Reputation
5 Guides authored
Cal Poly, Team 10-7, Livingston Fall 2016 Member of Cal Poly, Team 10-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G7
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 249
