This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
Les touches collent ? Vous voulez simplement retirer votre clavier ? Voilà comment faire.
Repérez la batterie et les dispositifs d'attache situés sous le Compaq Mini.
Repérez et enlevez les deux vis sous votre Compaq Mini, sur le compartiment de la RAM.
Enlevez les caches en caoutchoucs situés dans les coins de votre Compaq Mini.
Pour ré-assembler votre appareil, suivez les instructions dans l'ordre inverse.
4 other people completed this guide.
Special thanks to these translators:
62%
These translators are helping us fix the world! Want to contribute?
Start translating ›
3 Comments
hi, steps 5 and 6 are not needed. not sure about removing RAM either. If I look on my removed keyboard, all I see are three places for screws - those located nearby battery socket.
I think steps 3,4,5,6,7 are not needed! The essential problem in removing the keyboard is not shown: how to lift the keyboard! Use the flat side or back of a screwdriver to push the metal strips shown in step 8 up (in the direction of the keyboard) to lift the keyboard. Put your fingers under the edge of the keyboard and pull gently but firmly. There is some resistance of the holding cover.
Thank you so much for the link!
Alex -
