Ergomixx Blender (Bosch) disassembly
  1. Ergomixx Blender (Bosch) disassembly, Head Screws: step 1, image 1 of 1
    • The speed switch can be removed by placing it on position 3 (to be checked, we broke it without realizing it) and then pulling the switch out.
    • The 2 first screws are now visible.
  2. Ergomixx Blender (Bosch) disassembly, Case screws: step 2, image 1 of 1
    • The last 2 screws are hidden under a small plastic cover at the bottom of the motor block.
  3. Ergomixx Blender (Bosch) disassembly, GR Thermal Micro-switch: step 3, image 1 of 1
    • In our case, the thermal fuse was blown, i.e. the small white component labelled «Y51 H 120C».
    • First solution: remove the thermal fuse and place a shunt instead (a small wire). Downside: loss of the thermal protection on this "short working duration" blender.
    • Second solution: replace the thermal fuse (which is better) by a component with the same characteristics. In this case, probably with a fusing temperature of 120°C and a max. current 5A.
    • Thanks to Darr and to webpage http://elwo.ru/forum/34-1408-1 for the picture and for giving us the right hint.
5 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Louis Possoz
435 Reputation
3 Guides authored
Repair Café Louvain-la-Neuve Member of Repair Café Louvain-la-Neuve
Local Repair Groups
2 Members
6 Guides authored
3 Comments
Avant tout Merci beaucoup pour ce tutoriel!
Il m’a vraiment bien servi.
Je confirme que la bonne position, pour retirer le bouton du régulateur de vitesse, est 2 ( et non 3 ).
Il faut malgré tout le retirer délicatement ( j’ai aussi cassé pour avoir tiré trop fort )
Cordialement
Lionel
Cachou - Reply
Merci pour la procédure d'ouverture, mais malheureusement trop courte! Il faudrait y ajouter les 4 zones d'appui (2 par coté de jonction) pour savoir ou pousser exactement afin de libérer les verrouillages d'emboitement. J'ai pris énormément de temps pour ces zones et en douceur, j'ai réussi a libérer ces 2 pattes pour permettre l'ouverture dans la zone centrale du moteur. Personnellement c'était un fil d'alimentation cassé juste à la fin de la gaine de maintien en sortie d'appareil. panne classique si on enroule trop court le fil autour du mixeur.
Bref au total 3h pour réparer ce fil d'alimentation. (raccourci juste à la cassure)
Merci pour votre tuto
GHISLAIN DUFRANE - Reply
Bonjour @ghislaindufrane C'est un plaisir d'entendre que vous avez réussi à réparer votre mixeur ! Félicitations et merci également pour le précieux retour. iFixit étant un wiki, je vous invite à mettre à jour le tutoriel pour que les suivants puissent réparer encore plus facilement. La communauté vous sera infiniment reconnaissante !
Claire Miesch -
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 183
All Time: 13,681
