Introduction
The plastic shell the keyboard is enclosed is brittle and can break. This guide will show how to replace the plastic shell of the keyboard.
Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
Remove the sixteen 5 mm length screws using the Phillips head #2.
One of the screws may be located underneath a manufacturer's sticker.
Gently lift up and remove the plastic casing, making sure that the back case is free to move to avoid accidentally cracking the case.
